My Specs:
OCZ OCZ2N800SR4GK 4gb (2 Stick) SLI ready RAM
Apevia X-Jupiter Jr. Case
(Quad-Core)Intel(R) Core(TM) 2 Quad Q9400 @ 2.66GHz 1333FSB 6MB L2 Cache 64-bit
EVGA 750 SLI NVIDIA 750i SLI Chipset LGA775 Supports LGA775 FSB1333 DDR2/800 Mainboard w/GbLAN,USB2.0,&7.1Audio
635 Watts Power Supplies Sigma Shark SP-635W PSU
9800 gtx
Alright so I have had problems with freezing since I purchased my computer in 2008. The computer would freeze mid game but only during gameplay and usually about 10-20 min in. This was when I had 2 9400 gt in SLI. Then I called the company that built my computer and they sent me a new motherboard. I replaced the motherboard but after that I got a ps3 and stopped gaming on my PC.
Recently I got myself a 9800 gtx and upgraded to Windows 7 Ultimate. Now during gameplay the computer will freeze. By freeze I mean I need to hardboot to get the computer to run again. The mouse and keyboard wont work and the game will freeze on the fame its at.
Now I have tried a bunch of things:
- First things pointed to heat issues because my computer runs a little hot (60 c on GPU in game and 50 c on cpu in game) I cleaned out the case and all of the dust and got the temp to drop about 2 c This did not fix the problem
- Second I tested the GPU thinking it was a faulty card using 3d mark. Came back fine so that knocks out the GPU
- Third I tested the RAM first with testing program then by popping one stick out playing until it froze and then trying the other. The computer froze with either one in knocking out the ram.
- I had to replace the motherboard so that knocks out the motherboard
Recently a new problem has arose. When the computer is in sleep mode for an extended period of time I will have to hardboot to get the computer to work. Sometimes it resumes windows and sometimes i need to hardboot twice to get the option to delete the resortation data. I am not sure if these two problems are related.
Any help would be great
9800 gtx
