Question Need help with GPU power supply jack
Your GPU needs a single 6-PIN PCIE cable from the PSU. So just use the 8-pin split cable to only insert 6 pins, leaving the other two. Which PSU model are you having ?
Btw, I don't see any 8-pin cable requirement from the picture above though. It shows 6-pin instead. From where did you purchase this GALAX GPU ? Is it a legit model ?
