need help with my second build
ciaranmc2011
342
Ok i finished putting all my components together but something is wrong it turn on for a second the powers of again i though it might have been a dead psu but i did the psu test with 2 pins and its fullu functioning i don't even know were to begin know my specs
motherboard-gigabyte.g1 assasin killer 2 socket 2011
cpu-i7 3930k
ram-8gb crucial ballistix tracer
cpu cooler- h100i
psu- ocz 1000w 80 plus gold certfied
gpu-gtx 670
has anyone got any ideas to help me
ThomasJ93
597
Try starting with the absolute bare minimum. Just 1 dimm, no hard dis or ssd, no DVD drive, etc.
If you can, test the PSU in a different PC. That it turns on with the 2 pin test doesn't mean it's good.
If that doesn't work either, I'd say the motherboard is faulty.
