First of all, thanks for clicking on this link to help me!
I'm trying to build a good PC Gamer, but I'm not a professional. So, I need your help with the components of the PC. I would like to know if the components are good, what power supply I would need and what are the cables I would need (if need)
Case : DEEPCOOL GENOME II (integrated water cooling to save money) (279.99$ + 14.99$)
Graphic Card : MSI GeForce GTX 1080 Ti GTX 1080 Ti LIGHTNING (1,089.99$ + 9.99$)
MotherBoard : ASUS Z170 Pro Gaming/AURA (204.99$ + 9.99$)
Processor : Intel 7th Gen Core i5-7600K (316.65$)
Ram : CORSAIR Vengeance LPX 16GB (2x 8GB) (179.22$)
SSD : SAMSUNG 850 PRO 2.5" 512GB SATA III (319.99$)
HDD : Seagate BarraCuda 1TB 3.5-Inch SATA III 6 Gb/s (63.98$)
If you know better prices / better deals / more valuable components, I'm wide open to them ! Total : 2489.78$ plus taxes
I would like 4k monitor.
If this motherboard the same ? : https://www.amazon.ca/Optimization-Z170-Pro-Gaming-AURA/dp/B01J8QQD98/ref=sr_1_1?ie=UTF8&qid=1500350806&sr=8-1&keywords=ASUS+Z170+Pro+Gaming%2FAURA
All the link :
https://www.newegg.ca/Product/Product.aspx?Item=N82E16811853040
https://www.newegg.ca/Product/Product.aspx?Item=N82E16814137159&_ga=2.246646918.388317305.1500344713-1963375669.1487911805
https://www.newegg.ca/Product/Product.aspx?Item=N82E16813132877&_ga=2.158559032.388317305.1500344713-1963375669.1487911805
https://www.amazon.ca/dp/B01MRRPPQS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=EDU8BH19037J&coliid=I201406VM2M76S&psc=1
https://www.amazon.ca/dp/B0143UM4TC/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=EDU8BH19037J&coliid=I36FUSDU11NZWM&psc=1
https://www.newegg.ca/Product/Product.aspx?Item=N82E16820147361&_ga=2.184140580.388317305.1500344713-1963375669.1487911805
https://www.amazon.ca/dp/B01LNJBA2I/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=EDU8BH19037J&coliid=I34L0QBHBQ5SNU&psc=1
All the link :
