need help with possible new build
Ruin91
58
currently i'm saving up to build a ryzen based system that can both play games and host a few servers mostly ark servers.
what i'm wondering is will this build work to both play games and host a server at the same time?
i wont be building this pc until sometime in 2018(hopefully the ryzen refresh is out by then) because i am on Social security so i need to save up for like 8 months b4 i can build it.
PCPartPicker part list: https://pcpartpicker.com/list/vBVkYr
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor ($427.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Amazon)
Motherboard: Asus - STRIX X370-F GAMING ATX AM4 Motherboard ($171.98 @ Newegg)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory ($168.88 @ OutletPC)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive ($149.99)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($75.04 @ Amazon)
Case: Phanteks - Enthoo Pro M Tempered Glass ATX Mid Tower Case ($94.99 @ Newegg)
Power Supply: FSP Group - Hydro G 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Amazon)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit ($138.89 @ OutletPC)
Total: $1516.62
the games ill be playing are
League Of Legends
monster hunter world(when it comes out)
Dauntless(ftp monster hunter)
ARK survival evolved
new battrlefront
NOTE
i already own a gpu which is why its not in this list
The B350 motherboard overclock quite well and unless you need a certain that only the X370 has there's little reason to get one. Gigabyte makes really good boards so there definitely a good option.
i imagine by the time i actually build (around june/july)this the ryzen refresh will be out prolly not the next gen tho
im only curious if this setup as it stands would be able to host 2+ ark servers,game,stream all at the same time(the server are high rate/20+mods)
As is the build looks fine, plenty of CPU power, RAM & as long as you have a decent GPU it will game well. There are parts you can save money on such as changing the CPU to the 1700, using the stock AMD Wraith cooler & going with a B350 motherboard.
Well have to see how things look next year as there will probably be a Ryzen refresh but also Coffeelake refresh as well.
i ment to change the cpu over to the 1700 b4 i posted this but i forgot to .ill be getting the 1700 since it 296 at micro center(that includes the tax) im very weird about b350 mobo idky i jsut dont like mopst of them..the x370-f has had good reviews plus its from asus which is why i was going with it vs say the gigabyte gaming k5 or k3
