Need Help with Power Supply/Case (I think that's it)
mvhtek
9
Alright, so I'm not great with computer hardware. I understand what everything does, but unfortunately I haven't invested a ton of time (in the past few years) into understanding the differences between the hardwares (I'm a software guy).
This computer will be used mostly for coding (no video editing as of now). I will run Windows 7 with Ubuntu on a VM. I will be doing coding through Marmalade (should be a piece of cake if the machine can run Ubuntu VM easily).
I also do web development so I need to be able to run a server (temporary at least). Once again, not a difficult task, but my point is I need the cores.
I will run 2 monitors (currently 1920x1200 and 1600x1440) but I do plan on getting a third.
I occasionally play games, but I will not overclock or do anything fancy (occasional Crysis/LoL). The primary roll is as a coding/temp server.
This is what I was thinking:
CPU: Intel Core i5-4670K (3.4GHz)
Mobo: Asus Z87-A (supports 4 RAM slots) (do I need a Wireless Card with this Mobo?)
RAM: Kingston HyperX Blu 2x4GB (upgradable to 16GB if I get 2 more sticks right (even though it's pretty unnecessary at the moment)?)
Primary Hard Drive: Sandisk 128GB (SDSSDP-128G-G25?)
Secondary: None at the moment, but will get one eventually (need a case that can support a 1-2TB disk) (I currently have a 640GB and 2TB external, so space is not an issue).
Video Card: Asus GeForce GTX 660 (GTX660-DC2O-2GD5)
So now I need help with a case and a power supply. When I'm on planes I'll occasionally get a PC Mag or something similar. A couple years ago (I think), I saw an aluminum case that you could move the pieces around so you could fit any number of usb/other ports and put them wherever you want (so just about any mobo could fit). Does anyone know of this case? If not, I'm looking for something black/silver and sleek (preferably ~$100, but can go as high as $150). I don't need it to look fancy, just professional. And in terms of power supplies, does it really matter which one I get? Any help would be greatly appreciated.
Thanks in advance,
Matt
Why does the RAM need to be 1.5V? Is that what the Asus Z87-A requires because I couldn't find anything stating that.
I'm looking for a mid-tower (preferabley ~$100, but I can go as high as $150).
Graphics card updated to Asus GeForce GTX 660 (GTX660-DC2O-2GD5).
Ahh, I thought that would be mobo specific. Thanks for that. I guess I'll switch to the Kingston HyperX Red (1.5V sticks). Thanks for the help. I'm gonna search around for a few different towers. I appreciate the help.
Yea, I was just looking at Fractal and Lian Li. I really like the Fractal Design Define R4 Black Pearl (with and without the window). Is there any benefit to having the window or is it simply cosmetic?
Alright, so I'm pretty set on everything, the only question I have is for the PSU. The case I want (Fractal Design Define R4 comes with 2x 3pin fans. Are there any PSU's you guys recommend? All the PSU's I've found have 4pin connectors. I'm thinking $50-75 is preferred, but am willing to go a little over if needed.
Also, as far as internal wi-fi chips go, is there a recommendation, or should I just find a mobo with built in wi-fi?
