Hi there.
I am upgrading my pc but I'm having trouble choosing a case. I want to use an AiO NZXT Kraken x63. The cases that I'm choosing from are:
Fractal Design Define 7 Compact Dark Tempered Glass
or
NZXT H510 or 510i
From what I learned I know that the CPU block should be lower than the radiator and that the best way to install an AiO is at the top of the case. The NZXT case has only space for 1 fan cooler. So my question would be. Can I install my AiO on the front of the NZXT case so that the radiator would be higher than the CPU block or should I go with the Fractal Design case that has more space for fans at the top.
My pc specs:
edit:
should I think about upgrading my cpu to R5 3600? Just so I can switch my MOBO in time
or
NZXT H510 or 510i
My pc specs:
- NZXT 510 or Define 7
- ASUS ROG STRIX B450-F GAMING II
- HyperX 16GB KIT DDR4 3200 MHz CL16 RGB FURY
- Ryzen 5 2600
- RTX 2060 Founders Edition
- NZXT Kraken x63
- Seasonic Focus Gold 550FX
- NOCTUA NF-A14 PWM Chromax Black Swap
edit:
