Question Need help
Apr 16, 2024
37
EVGA GTX 970 SC makes 3 beeps (beep pause beep pause beep) on the bios screen then goes onto this screen View: https://imgur.com/a/2fFr6mP
the underscore is flashing btw if that means anything and i can’t get out of it or enter bios and can’t get into windows unless i change the gpu.
Specs
i5-2320
8gb ram ddr3
PSU Mi-X81075CD 1075watts
128 test ssd
evga gtx 970 sc
Windows 10 home
https://www.ebay.com/itm/355614659132
That is a bad quality PSU for your build. I would look into sourcing(borrow, not buy) a reliably built PSU and see if the issue persists.
You forgot to mention the make and model of your motherboard?
it is probably the psu ive been having a issue since july 17 where the pc boots but no display and i have to keep restarting it until it gets a signal but idk if it’s the psu or motherboard
