So I have a couple of questions. I have AMD Phenom II x4 955 BE, ASRock 970 Extreme4 motherboard, Sapphire Radeon HD 6870, Cooler Master Storm Scout case.
First question: The stock fan for the AMD 955 for some reason does not fit into the mobo. The notch / lever on the fan is about 2 cm too high for the notches that match it on the motherboard. If I try to force it in, I feel like I will break the CPU and Motherboard.
Second question: For the videocard, is it fine to connect it directly to the PSU, or do I have to use the addaptar that comes with it (which also connect it to the PSU, but in a different pin format).
Third question: My hard drive and optical drive didn't come with any cables that connect to the motherboard. Do I have to buy those separately? The optical drive says SATA on the back, but I don't know kind of connection cord the hard drive needs for the mobo. The hard drive just says 'data' for the other connection.
Also, there is no AC '97 cord on my motherboard, which is needed for one of the wires on my case (Cooler Master Scout)
The case also has connection cords for: 'Power SW' 'Restart SW' 'H.D.D led' 'Power led+' 'Power led' all of which are 2 pin connections. I don't know how or where to connect these.
I am terribly sorry, but this is my first time building a computer, and I am dearly lost. Sorry
