G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hello all.
I have an M7VIT Biostar mobo with AMD 2000 cpu on it. After installing a
new BIOS on my board with a file I dled from the BIOSTAR site all sorts of
errors started popping up. Most common is that some devices, like sound or
video might not load right from the first boot. If I do a cold reset
everything works fine after that.
An obvious thing to try would be to install earlier versions of BIOS, but
BIOSTAR has only 1 ( the latest) version of bios image file available for
download. Is there something like an archive on the net where I can find
earlier versions of BIOS for my board?
Thanks,
Eugene.
Hello all.
Thanks,
Eugene.
