Question Need opinion for PC BUILD
Oct 28, 2020
6
cpu/: ryzen 9
gpu/:3090
Aio 360mm
motherboard :/ x570 msi meg ace
ram:/ 3600 cl16 2x32gb appertently im bottle necking with this ram
psu:/ 1000₩ gold 80+
Anidees AI Crystal XL AR 3 ATX Full Tower Case
PCPartPicker Part List: https://pcpartpicker.com/list/DVt3t8
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor ($424.99 @ Newegg)
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler ($189.99 @ Best Buy)
Motherboard: MSI MEG X570 ACE ATX AM4 Motherboard ($358.99 @ B&H)
Memory: Crucial Ballistix 64 GB (2 x 32 GB) DDR4-3600 CL16 Memory ($403.39 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive ($114.96 @ Amazon)
Storage: Crucial P1 2 TB M.2-2280 NVME Solid State Drive ($202.50 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Newegg)
Video Card: PNY GeForce RTX 3080 10 GB XLR8 Gaming REVEL EPIC-X RGB Video Card ($759.94 @ Office Depot)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($124.99 @ Corsair)
Operating System: Microsoft Windows 10 Pro 32/64-bit ($199.99 @ Adorama)
Monitor: Asus TUF Gaming VG27AQ 27.0" 2560x1440 165 Hz Monitor ($424.99 @ Amazon)
Keyboard: Razer Huntsman Tournament Edition RGB Wired Gaming Keyboard ($129.99 @ Amazon)
Headphones: Rosewill Audiowave H9000 Headset ($55.64 @ Amazon)
Speakers: Creative Labs Pebble 2.0 4.4 W 2.0 Channel Speakers ($22.98 @ Newegg)
Webcam: aoni A31 Webcam ($39.95 @ Adorama)
Total: $3508.28
Generated by PCPartPicker 2020-10-28 21:58 EDT-0400
Darkbreeze
Retired Mod
Well, it's pretty hard to offer an opinion when your listing is pretty ambiguous.
There are several "Ryzen 9" models. MANY 360mm AIO coolers. Dozens of "1000w Gold" power supplies. Hundreds of CL16 3600mhz memory kits.
Knowing the specifics of each component choice is what helps to determine if that choice is any good or not, and is exactly what you haven't offered, so it's literally impossible to say whether any of it is recommended or not. And you can probably add RTX 3090 to that as well, since there are always good and not so good choices when it comes to just about every kind of graphics card series.
Oct 28, 2020
6
Total: $3508.28
Phaaze88
Champion
Ambassador
About all I could comment on is gaming. If this build is for more than that, then someone else needs to chime in.
Here goes...
IMO:
-Cpu is a bit much for just gaming.
-Overkill cpu cooler. A 3900X isn't that power hungry under full load; even a 9700K can be pushed to draw more power than it.
-:whistle:. Pricey motherboard.
-64GBs of ram. No way this is for a gaming rig, right?
=500GB SSD would've been plenty for an OS only drive.
-Dang. With the kind of money you're looking to spend, you may as well have gone all SSD...
-That chassis is big, and will make your selection look unnaturally small inside it, giving it an empty look. That model is better suited for large custom liquid projects.
-Spending big on most of the internals of the PC, but the peripherals seem like an afterthought.
3/10.
Gaming + streaming + video/photo editing: 4/10. The 3900X makes more sense for that. Everything else pretty much stands.
Just looking to splurge a bit: 7/10. Points taken off because of the HDD, peripherals, and could've gone for an even beefier psu.
Reactions: GarrettL
Phaaze88
Champion
Ambassador
@BuildS2021
64GBs for video editing though? I could see that for photo editing 4K or other high res images...
I checked the product support page for the Anidees AI Crystal XL AR 3, and I don't see anywhere mentioning dual system support.
Off the top of my head, I know Phanteks' Enthoo Pro 2, Enthoo 719(formerly Enthoo Luxe 2), and Corsair 1000D, have dual system support, but whether they're available to you...
You also need a psu that can accommodate a dual system, and there aren't many that can do that; 2 in 1 systems are very niche. Phanteks has their Revolt X for that application.
Or you'll buy 2 psus, jerry-rig the 2nd outside the chassis, and get a little creative with the wiring so that you'll be able to turn them both on - that's beyond me.
Now that I know the purpose, I need to revise my scoring a little:
=Motherboards should be more about their feature sets than anything else. If you know exactly what you need here, great! If not, it can be easy to overspend. Imma cut you some slack with this one and leave it neutral.
-64GBs of ram.
-Chassis doesn't natively support dual system builds.
-Psu doesn't support dual system builds either.
-Spending big on mostly the internals of the PC, but the peripherals seem like an afterthought.
4/10.
If I had to buy this system for myself I would probably go for something like this instead. 400 dollars for 64GB CL16 is crazy. CL18 at 240 dollars for 64GB will do the job.
Better PSU over the RM. RMX has better capacitors. Phanteks P600S case. SN750 SSD is better than crucial P1.
But Phaaze88 said that the PSU does not support dual system so you will have to take a look at which PSU does. The Phanteks P600S case does support dual system.
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor ($439.00 @ Amazon)
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler ($90.00)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard ($179.99 @ Amazon)
Memory: G.Skill Ripjaws V 64 GB (2 x 32 GB) DDR4-3600 CL18 Memory ($239.99 @ Newegg)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive ($62.99 @ Amazon)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive ($109.00 @ Amazon)
Storage: Western Digital SN750 1 TB M.2-2280 NVME Solid State Drive ($129.99 @ Amazon)
Case: Phanteks Eclipse P600S ATX Mid Tower Case ($149.99 @ Newegg)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($144.99 @ Best Buy)
Total: $2505.87
Generated by PCPartPicker 2020-10-29 19:04 EDT-0400
GG, this chassis does darn near everything, doesn't it? Well, it won't fix me a cup of coffee in the morning...
Plus, it's about 150USD?
I may have to get me one...
Every morning there is a hot coffee cup inside the case waiting for me. In all seriousness that case is such a good case. I had 2 HAF922 on my 2 last systems and I don't even know why I didn't buy a P600S before. I should have.
Reactions: Phaaze88
Oct 28, 2020
6
Dual pc build is later down the trsck psu will be upgraded when i decided to build 2 pc in one case
All though it doesn't state is dose or don't support dual setup im an i have cert in engineering and fabrication so i can fab stand offs and set them in place so case can support dual set up.
Oct 28, 2020
6
PCPartPicker Part List: https://pcpartpicker.com/list/v8FLPV
CPU: AMD Ryzen 9 3900XT 3.8 GHz 12-Core Processor ($454.99 @ Amazon)
Motherboard: MSI MEG X570 ACE ATX AM4 Motherboard ($358.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($142.99 @ Amazon)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($173.98 @ Newegg)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive ($119.99 @ Adorama)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive ($149.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card ($700.00)
Case: Phanteks Eclipse P500A D-RGB ATX Mid Tower Case ($140.00)
Power Supply: Corsair RMx 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($204.99 @ Corsair)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($139.88 @ Other World Computing)
Total: $2695.78
Generated by PCPartPicker 2020-11-06 02:57 EST-0500
Be quiet 280mm pure loop AOI
EXTRA 3 FANS FOR TOP
CASE P500A is dual pc capable
