A Gateway MX6124 is giving me serious heartburn. It locks up at random very frequently, to the point of being unusable. It has a 2GB memory module, and it's running XP SP3, fully updated. Here are my experiences:
1. The Gateway INF file will not install. When I try to do so, I get "Diskcannot be read" error. There is not a problem with the file or with the drive. The file has been downloaded multiple times and run from both a hard drive (multiple instances) and from a USB drive. There is something wrong with the build. The generic Intel INF drivers for this motherboard appeared to load correctly.
2. The Conexant_Audio_6.14.10.0565.exe drivers will not install. If I go to Windows Update, Conexant drivers load and work. There have been similar reports in other posts.
3. The hard drive and the memory are rather new. There are no problem areas on the hard drive. The memory module just passed MEMTEST with no problems.
At this point, the only two things that I can think of are:
1. The memory module is a single 2GB module. The Crucial site says that the unit has a limit of 1GB per slot. This problem is not likely because it should work or not work, and MEMTEST says there is no problem with the memory.
2. Maybe it would make sense to use the Intel utility to load only Intel generic drivers where they are available. It seems that Gateway forgot about this computer a long time ago. It belongs to someone who does not have enough money to throw it away and buy a new one.
Do you have any suggestions for further troubleshooting?
