Saga Lout :
Could you please bring up the Command Prompt - in XP Start>Run - later versions Search>Run) and at the prompt, type the following:-
cmd /k ipconfig /all
then press Enter. Right click anywhere in the black form and choose SelectAll then press Control and C together. To reproduce that in a Post an Answer form here is to press Control and V, then you can add anything you like to the message. With that information, someone will be along to help.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Deadlierduck21>cmd /k ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 94-DE-80-2A-F9-37
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::a5a4:67b9:86d6:5ba2%11(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, May 26, 2013 8:24:06 AM
Lease Expires . . . . . . . . . . : Monday, May 27, 2013 8:24:05 AM
Default Gateway . . . . . . . . . : 10.0.0.1
DHCP Server . . . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 244637312
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-FB-45-6A-94-DE-80-2A-F9-37
DNS Servers . . . . . . . . . . . : 10.0.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{7D9621A8-51BA-4C8A-9109-85CCC0BEEFC4}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:24be:654:ba7b:d4b0(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::24be:654:ba7b:d4b0%13(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
