Need some advice
filippekar2
12
So I live in Serbia and everything is expensive and our salaries are low.
I wanted to build a pc with:
- i5 7500
- gtx 1060 6GB
- 1TB HDD
- 8GB DDR4 RAM
- 600W PSU
(I have never build a pc before)
Now in my country that would cost 1500$.I found a prebuilt PC like this and it has 240GB SSD along with my HDD and it costs 1000$ but everyone is saying that prebuilt is trash it's to expensive so I don't know.Plz help.
Sorry for my bad english.
same features for 1/3 less is worth looking at. pre-builts are not trash, they just tend to use lesser quality parts than you would use for a custom build.
but for the millions made and sold, not as many have issues. just know if you decide to upgrade later, you'll likely have problems. power supplies are not the best and probably won't be able to upgrade other stuff without problems.
if you link the pre-built system can look it over and see if it's decent or not
will be a cheap mobo and power supply but for the a locked cpu, it's not a big deal really.
can replace power supply down the line if need be and still be under a custom build if your prices are right.
for a 1/3 savings, i'd say go for it. not a bad looking case either
For 1500$ you can try much better
PCPartPicker part list: https://pcpartpicker.com/list/yDYNHN
Price breakdown by merchant: https://pcpartpicker.com/list/yDYNHN/by_merchant/
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor ($289.99 @ SuperBiiz)
Motherboard: ASRock - Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard ($79.99 @ Newegg)
Memory: *Team - Vulcan 32GB (2 x 16GB) DDR4-3000 Memory ($259.99 @ Newegg)
Storage: SanDisk - SSD PLUS 480GB 2.5" Solid State Drive ($144.99 @ Best Buy)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($74.75 @ OutletPC)
Video Card: *PNY - GeForce GTX 1070 8GB XLR8 Video Card ($409.99 @ Best Buy)
Case: Fractal Design - Define R5 Blackout Edition ATX Mid Tower Case ($87.99 @ NCIX US)
Power Supply: *Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($52.98 @ Newegg)
Total: $1400.67
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2017-08-26 17:49 EDT-0400
And even for 1000$
PCPartPicker part list: https://pcpartpicker.com/list/f6fdkT
Price breakdown by merchant: https://pcpartpicker.com/list/f6fdkT/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($197.43 @ OutletPC)
Memory: Corsair - Vengeance LED 16GB (2 x 8GB) DDR4-2666 Memory ($144.89 @ OutletPC)
Storage: Kingston - A400 240GB 2.5" Solid State Drive ($88.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1060 6GB 6GB OCV1 Video Card ($279.89 @ B&H)
Total: $1006.81
Generated by PCPartPicker 2017-08-26 17:52 EDT-0400
