[SOLVED] Need some help picking a PSU
Lucas G
54
7
535
So unfortunately I didn't follow my gut when getting a new psu, it's now making some weird noises so I'm thinking of getting a new one. I really don't wanna spend more than $100 unless absolutely necessary. And the PSU Tier list doesn't help a lot.
Here are my PC Specs:
Motherboard: B450 Pro Carbon AC
CPU: AMD Ryzen 5 5600x
GPU: Rx 6650 xt
RAM: G.Skill RipJaw V 3000 mhz
PSU: MasterWatt 650W Bronze
Can't go wrong with SuperFlower and Ledex III model. Corsair is another brand but bit more expensive with Rmx line. There are many tier A psus, i usually go with Corsair (in Australia, can't get SuperFlower here locally) and have owned Rmx (Gold rated), Ax and Hxi (Platinum), all have been good.
https://www.amazon.com/Corsair-RM650x-Fully-Modular-Supply/dp/B08R5Q1W7R/ref=sr_1_1
Reliability isn't the issue with any of these but budget vs wattage will depend on if you see yourself jumping to a more powerful gpu in future. Something around 650w, possibly 750w if you do see yourself doing that.
