Need some help upgrading my old pc.
Christian Thor
Commendable
Feb 20, 2016
5
Hi I'm looking to upgrade my pc's specs, and i need some help. I have a 3 year old gaming pc, and i want to get some better performance out of it.
I was thinking abouy upgrading my "Radeon 7700 series" to an "Sapphire radeon r9 380 nitro".
https://www.overclockers.co.uk/sapphire-radeon-r9-nitro-380-4096mb-gddr5-pci-express-graphics-card-with-backplate-11242-13-20g-gx-374-sp.html
Would that work/would it be compatible with my system?
Also, please tell me if i need to upgade some of my other parts to get a better gaming experience.
Specs:
CPU: Intel Core i5 3350p
Operating System: Windows 10 (64-bit)
Motherboard: Gigabyte H61M-S1
RAM: 8GB Kingston (1x8GB)
Hard Drive: HDD ATA 1TB
GPU: Amd Radeon 7700 series
PSU: 500W Cooler master
Oh, and another thing. I have also been looking for a SSD to speed up my boot time and to have my games on. Is this one good?
https://www.overclockers.co.uk/samsung-120gb-850-evo-ssd-2.5-sata-6gbps-32-layer-3d-v-nand-solid-state-drive-mz-75e120b-eu-hd-190-sa.html
You forgot to list your case so up to you to make sure it fit's but you need to list the exact model number of the power supply a lot of the cooler master power supplies are just junk and can put out nothing near their rated watts.
The SSD will work I would look at the 250GB model it's just a few bucks more and will be easier to manage.
Thank you. I will check if the card can fit.
As for the power supply, i think it is this one...
http://www.coolermaster.com/powersupply/thunder/thunder-500w/
I dont really know how good it is.
Thank you. Can you recommend a good one?
