- Hey There.
I am trying to overclock My [Ryzen 7 2700x] as much as possible, At the same time, learn as much as I can about overclocking using more advanced settings in [UEFI Bios]
My Specs are:
[PSU] - Corsair RM850x, 850W
[RAM] - Corsair Vengeance RGB PRO DDR4 16GB
[CASE] - Corsair Spec Omega RGB
[PCB] - Asus ROG Strix X470-F Gaming
[GPU] - RTX 2070 Msi Gaming Z
[CPU] - AMD Ryzen 7 2700x
[AIO] - Corsair Hydro H150i PRO RGB (360mm)
Some people might ask:
[Do you use the laters bios?]
'No I do not, I am using Version '4804' with was published '2019/06/05''
The reason why I don't use the more recent BIOS is that when I tried using it, it had problems booting windows and all my [Proflies] where deleted, and was constantly black screening. I also heard that this Updtade was rushed and is the same update that added [PCIE 4.0], Again I don't know why my pc acted like that, but it might have something to do with that.
[Why don't you overclock you ram?]
I was able to use Asus's [D.O.C.P] Profile, and then change it form [3200Mhz] witch is the rated speed of my ram, to [3400Mhz] witch did show improvement in performance with [Cinebench R15] witch is also the program I use to check stability. altho I know there are better ways to check stability, I just need something quick as of speaking so I don't use all day long on
I also have plans to learn more about Ram Overclocking once I have learned most about [CPU overclocking]
[Why not use XFR?]
I am doing a lot of Emulation, which hits hard on the [RAM] and [CPU]
I want to gain as much form my CPU and RAM as possible. but this post is mostly about some [BIOS Settings]
I am pretty sure I can get more form [Manuel Overclocking] defiantly, with that [360mm AIO] or? IDK.
Now, I am having a hard time learning everything about more [Advanced OC Settings] as every tutorial is using terms as [WPM 15%, and 20%] witch really doesn't tell me anything, cause I am new to this settings. I am referring to settings in the [BIOS tab] called: [DIGI+ VRM]
Here is an image of how that page looks
The specific Settings I want to learn more about is called.
[VDDCR CPU Load-Line Calibration] >>>>>> [Level 1,2,3,4 & 5]
[VDDCR CPU Current Capability] >>>>>> [100%, 110%, 120%, 130% & 140%]
[VDDCR CPU Switching Frequency] >>>>>> [Auto, Manuel.]
'Again, I am trying to figure out what all of thies setting actually means, and if they help me with overclocking.'
For example, I tried overclocking my [Ryzen 7 2700x] to [4.275Ghz], for that to be stable I needed more than [1.481V], But I was able to run it stable at [4.275Ghz] with [1.481V] when I used the setting called [VDDCR CPU Load-Line Calibration] set to [Level 5].
So will change some of this setting improve my [CPU OC]?
BTW: can someone explain how 'Offset voltage works?' when I tried it, it was just like using [Manuel Voltage], The [Offset voltage] was just completely Statick, it didn't fluctuate, Witch, I thought was the point of [Offset Voltage.] or maybe I just mess it up?
Anyway I know there was a lot of questions, sorry about that
I just don't want to make 100 posts about different settings, . . . so I just made a huge one instead.
And, again.
I am new to these settings so I don't know too many words when it comes to [Advanced settings].
- Thank's for reading <3
My Specs are:
[Why not use XFR?]
And, again.
