[SOLVED] Need to convert Ethernet Port to Powered USB Port?
Apr 3, 2021
6
I want to share an external hard drive between two computers at home. I read that one option (the easiest and cheapest one) would be to connect the external hard drive to my modem. My modem does not have PoE ports. What kind of adapters should I get to make the most efficient connection?
My initial thought was one Ethernet cable to plug into the modem and to an Ethernet power injector adapter. Then another Ethernet cable from that to an Ethernet to USB adapter, but I am having a hard time finding that kind of adapter because I'd need Ethernet male to USB female, not just the usual Ethernet to USB. Does that kind of adapter even exists?
Does anyone have any advice? Is it even possible?
Thank you. My modem/router is CGM4141COX . Really hoping I can do it that way, since I believe a NAS device would be a lot more expensive, right?
Depends on what you consider "expensive".
$100 + your drive. Accessible from any and all systems in the house.
https://www.amazon.com/Synology-DS120j-DiskStation-Diskless-512MB/dp/B07ZKSLVT5
2 bay for $170
https://www.amazon.com/Synology-DiskStation-DS220j-Diskless-2-bay/dp/B0855LMP81
NOTE: you'd have to completely reformat the drive, so any data needs to be elsewhere first. Then, copy it back.
It is not a adapter problem it is a communication issue.
Ethernet and usb use very different method of transferring data. It is kinda like translating between say english and french but it is done both at the electrical level as well as the logically how the data is formatted. Just providing power to end device would actually be a somewhat easier challenge.
You are not going to get this done with some fancy cable it would almost need some kind of small computer like device.
It might be cheapest to buy a small NAS enclosure and move the hard drives. Maybe you could find a inexpensive router that support external USB hard drives and use it purely as a NAS.
Reactions: Kira_Kira
I don't want to have to go turn on the computer with the shared drive every time I need to use it on a different computer .
Some device needs a little bit of a brain to be able to share this drive and its data.
Either a drive in an external enclosure(with its own power), and connected to a router with a relevant port and functionality. Probably USB.
Or a small NAS (Network Attached Storage).
2 bay for $170
