Need to disassemble top of Corsair 500r
visioncharm
21
Apparently as I just installed my dvd drive, I also accidentaly knocked out the cabled that connected the front panel of my case to the mobo. Which made it so I had to start my pc by pushing the power button on the mobo, which isnt a big deal. But I still need to figure out a way to get those cables back in, especially since now my side fan, a really big fan(like 200mm i think) now cant turn on, which makes me worry that my pc could overheat now.
Does anyone here know the best way to get to the cables of the front panel? If you have this case, or if youve seen it, you should know that these cables are in a very inconvenient spot, and putting them back in is near impossible. Its just such a hard angle to put your hand through with the storage compartments for things like my dvd drive in the way
