Need to help with a wierd build
kristisdbs
175
Hello Tom's community. Today i need a big help from you. I need to know what are good builds:
1. Entry level build (lowest budget, entry level gpu, cpu and so on)
2. Mid-range build (mid range cpu,gpu and so on)
3. Enthusiast build (a better build, you know what i mean)
4. High end build (for gamming, with high end gpu like 780,770 gtx )
5. Extreme build (best builds with cpu like Intel Core i7-3960X and gpu like gtx690 or titan or 7990...)
Money is not a priority here, but they should cost as I wrote and they should be good price to quality (like low end cost less than extreme). I am building these 5 builds for gamming, application reviews (games like crysis 3, metro last light and others that come in the future and programs like c++, 3d max and so on and on) I will be testing them on different builds) :) also i live in Lithuania, and no i won't do anything on higher resolution than 1080p
P.S. i tried looking myself looking at these gpus,but it is quite difficult to choose a case and cpu, MoBo http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107.html
Go to home page
Where is says:
Latest Articles - All - Build Your Own - Cases - Coolers - CPU - Graphics Cards - Memory - Motherboards - Power Supplies - Software - Storage
Click on Build Your Own
All ya answers right there
Go to home page
Where is says:
