I have an ASUS R7 250. It's about 4 years old now and the gpu itself works fine but the fan has started consistently rattling. It cools the gpu properly but the noise is so loud I have to keep the fan running constantly at 67% (and even that takes some fiddling, stopping and restarting it etc.). I want to try lubricating it since cleaning didn't fix it.
I found out that fans provide access to the bearing by taking off the sticker on the back but when I took the sticker off mine it only has a square hole and I can see components through it, which don't look like they'd like lubricant poured over them. I've added photos below for clarity.
(embedding the image doesn't work for me so I've linked to it instead)
Photos of fan without the sticker
So what is this hole and does it let me lubricate the bearing? Do I need to access the fan from the other side perhaps or detach it? The way it is right now makes it impossible to pop off so I'd have to remove the fan from the heat sink, to which it's both clipped on and glued on. Would it be ok if I dissolved the glue and then just clipped it on back after lubricating without re-glueing? It looks like the clips alone would be ok but I've never done this before so I don't know.
