Question Netgear CM1000 DOCSIS 3.1 Power Levels
Jun 17, 2023
Can someone review my power levels? Optimum is telling me my modem is going bad?? I never had an issue until ATT started digging up the neighborhood for fiber lines. I pay for the 1G plan and am now getting maybe 90 down and still 50 up. Used to get 900 down. TIA
ProcedureStatusComment
Acquire Downstream Channel663000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDAPM
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25619663000000 Hz3.9 dBmV39.3 dB207367512665442742
2LockedQAM2562561000000 Hz5.0 dBmV39.9 dB207242733571293163
3LockedQAM2563567000000 Hz4.7 dBmV39.8 dB207243597571593150
4LockedQAM2564573000000 Hz4.7 dBmV39.7 dB207243204370173109
5LockedQAM2565579000000 Hz4.5 dBmV39.7 dB207245400470933120
6LockedQAM2566585000000 Hz4.2 dBmV39.7 dB207247461068923081
7LockedQAM2567591000000 Hz4.3 dBmV39.7 dB207248482369982997
8LockedQAM2568597000000 Hz4.2 dBmV39.7 dB207248957969363065
9LockedQAM2569603000000 Hz4.6 dBmV39.8 dB207251344068652998
10LockedQAM25610609000000 Hz4.4 dBmV39.6 dB207253253068362981
11LockedQAM25611615000000 Hz4.8 dBmV39.6 dB207254166868372925
12LockedQAM25612621000000 Hz4.6 dBmV39.4 dB207255258068522976
13LockedQAM25613627000000 Hz4.6 dBmV39.4 dB207256131069152929
14LockedQAM25614633000000 Hz4.1 dBmV39.4 dB207257092168152893
15LockedQAM25615639000000 Hz4.2 dBmV39.5 dB207257725066842887
16LockedQAM25616645000000 Hz3.6 dBmV39.2 dB207258713366662858
17LockedQAM25617651000000 Hz3.9 dBmV39.2 dB207260002366582739
18LockedQAM25618657000000 Hz4.0 dBmV39.3 dB207261012565962736
19LockedQAM25620669000000 Hz4.4 dBmV39.5 dB207261898165322682
20LockedQAM25621675000000 Hz4.2 dBmV38.9 dB207262527565552603
21LockedQAM25622681000000 Hz4.6 dBmV39.5 dB207263753664812538
22LockedQAM25623687000000 Hz4.0 dBmV39.5 dB207264700466512522
23LockedQAM25624693000000 Hz3.8 dBmV39.5 dB207265599464772562
24LockedQAM25625699000000 Hz3.4 dBmV39.4 dB207266374163492494
25LockedQAM25626705000000 Hz3.4 dBmV39.1 dB207267452162582491
26LockedQAM25627711000000 Hz3.1 dBmV39.1 dB207268357563222431
27LockedQAM25628717000000 Hz3.5 dBmV39.1 dB207269529362172405
28LockedQAM25629723000000 Hz3.4 dBmV39.3 dB207270339762982388
29LockedQAM25630729000000 Hz3.8 dBmV39.0 dB207271306562312378
30LockedQAM25631735000000 Hz3.7 dBmV39.3 dB207273499561762324
31LockedQAM25632741000000 Hz3.5 dBmV39.5 dB207272608660002410
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
Upstream Bonded Channels
1LockedATDMA4137500000 Hz49.5 dBmV
2LockedATDMA4230700000 Hz47.8 dBmV
3LockedATDMA4325000000 Hz46.3 dBmV
4LockedATDMA4421400000 Hz45.5 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 233795000000 Hz2.6 dBmV37.8 dB1588 ~ 250715038794431238028049317
2Not Locked000 Hz-49.0 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
1Not LockedUnknown00 Hz0 dBmV
2Not LockedUnknown00 Hz0 dBmV
2023-06-17, 13:04:31​
Notice (6)​
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33 ; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 .;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-17, 13:03:58​
Notice (6)​
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33 ; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 .;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-17, 13:03:47​
Notice (6)​
CM-STATUS message sent. Event Type Code: 16; Chan ID: 33 ; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 .;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-17, 13:02:42​
Notice (6)​
2023-06-17, 13:02:10​
Notice (6)​
CM-STATUS message sent. Event Type Code: 16; Chan ID: 33 ; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 .;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-17, 13:00:41​
Notice (6)​
2023-06-17, 12:59:53​
Notice (6)​
CM-STATUS message sent. Event Type Code: 16; Chan ID: 33 ; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 .;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-17, 11:55:43​
Error (4)​
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-16, 02:10:19​
Notice (6)​
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 .;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
2023-06-16, 02:10:10​
Error (4)​
Primary address failed, secondary active;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
Warning (5)​
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
Time Not Established​
Critical (3)​
DHCP failed - RS sent, no RA received;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
Notice (6)​
Honoring MDD; IP provisioning mode = APM​
Critical (3)​
No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
Critical (3)​
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;​
Critical (3)​
Critical (3)​
Critical (3)​
2023-06-15, 22:09:24​
Critical (3)​
Critical (3)​
Critical (3)​
Critical (3)​
2023-06-15, 21:48:26​
Critical (3)​
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:0c:6b:c8:e7:d0;CMTS-MAC=00:01:5c:b4:c8:98;CM-QOS=1.1;CM-VER=3.1;​
Critical (3)​
Critical (3)​
Critical (3)​
Critical (3)​
Critical (3)​
Critical (3)​
2023-06-13, 16:59:09​
Critical (3)​
Resetting the cable modem due to docsDevResetNow​
2023-06-13, 16:56:18​
Critical (3)​
2023-06-13, 16:55:58​
Critical (3)​
Critical (3)​
Critical (3)​
2023-06-13, 16:53:32​
Critical (3)​
Critical (3)​
Critical (3)​
Critical (3)​
<Moderator Note: Do not post long log listings without using the "[ spoiler ] [ /spoiler]" tags>
Your upstream power is not real good especially on the channel that gets 49.5. I forget the exact recommended values but when you get close to 50 you start having issues.
Key here is you are getting a lot of uncorrected code words....ie packet loss. Now if this has been running for a month then it is not bad but I suspect this only a couple days.
Sync errors are bad they many times cause the modem to retrain.
What this generically means is the ISP is having issues hearing your modem even though your modem can hear the ISP fine....you have good numbers on the downstream. This generally is a cable issue....most times outside your house. You can check all the cable you have access to. You are looking maybe for dirt or water in a connection. Maybe move the modem to connect to directly to the cable coming from the outside of the house without splitters or other stuff connected.
After that only the ISP can check stuff. Can be as simple as a small bit of water got into one of the connectors in one of the boxes on the street.
Jun 17, 2023
Thanks for the advice. I have a feeling the ATT fiber guys did something. The dug in my yard to bury their fiber lines. I'm wondering if they hit my cable line in the process. So you don't see anything wrong with the modem? (besides what you mentioned) I should probably just have a tech come out.
If it is the main ATT fiber run where they are boring that they have all kinds of little flags so they don't hit power,water,gas phone lines etc. It was quite a show when they were doing it near me. Now the runs from the new boxes on the street to the house that they just use a shovel and cut a slot. They still have everything located so they don't for example hit a even a sprinkler system or in theory the phone and cable lines.
It would be a massive pain if they damaged the coax cable under the ground going to the box. They would have to run a new one and they would take the chance of cutting att fiber who would send a tech to replace that.
Hopefully it is something simple.
Now after it is all fixed you likely should check att rates. For me they were almost $40 a month lower for faster services and that was even after the first year. The first year they have larger discounts plus you can get like $150 for using their online thing to sign up rather than calling a phone number. There 5gbit plan though is kinda expensive.
For me comcast could care less, they were already more than att and then they increased the rates and when I called the best they would do is remove the new increase for 1 year even though they were $40 more before the increase.
Jun 17, 2023
Thanks for the help. I'm actually getting Optimums 1gig plan for a good price ($59) as the newly advertised fiber from ATT out here is $80 for the same speed. I've also been with them many years. You would think they would help a brother out!
