[SOLVED] New Build - Monitor and Part Advice
theeOBESEninja
20
I am looking to build a new gaming rig looking to run pretty much all AAA latest games on max settings or at least close to
I need to buy a new monitor but I dont know whether to use the budget for a 1440p monitor or 1080p and 120hz
Monitor budget is £150
Parts advice would be good also - Leeway on the price isn't really an option
I chose the Motherboard due to the WiFi and Bluetooth additions that I need also
PCPartPicker Part List: https://uk.pcpartpicker.com/list/VJsXq3
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (£155.00 @ Amazon UK)
Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard (£128.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory (£69.98 @ Amazon UK)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive (£107.99 @ Amazon UK)
Video Card: MSI Radeon RX 5600 XT 6 GB MECH OC Video Card (£289.97 @ Amazon UK)
Case: NZXT H510 ATX Mid Tower Case (£73.08 @ CCL Computers)
Power Supply: Corsair Vengeance 650 W 80+ Silver Certified Semi-modular ATX Power Supply (£74.98 @ Amazon UK)
Total: £899.99
Generated by PCPartPicker 2020-05-22 11:43 BST+0100
1080p would be a better resolution unless you can upgrade the video card, for the motherboard be prepared to have to update the BIOS to work with the processor ( that board can be updated without a processor) the power supply is out of stock if supplies over their are like in the US good luck even finding a decent one that is in stock.
