[SOLVED] New build parts list
Mar 26, 2022
Looking to build a new setup for gaming and online classes. Already own a 3060ti and 6700xt to use for graphics card ( might use both to mine in the same build for the time being )
Any thoughts on this list below ? Fairly certain I want to go with 12600k 0r 12700k, 1tb os storage, 1tb game storage, 2x16gb ram, enough psu watts for 2 cards. I'm up for suggestions on anything left out ( like cpu cooler, etc ) and also suggestions for things that may be better value than what I have included in the list.
Thanks y'all. Appreciate the knowledge 🧠
PCPartPicker Part List
Type|Item|Price
CPU | Intel Core i5-12600K 3.7 GHz 10-Core Processor | $278.98 @ Newegg
Motherboard | Asus TUF GAMING Z690-PLUS WIFI D4 ATX LGA1700 Motherboard | $249.99 @ Newegg
Memory | Team T-FORCE DARK Za 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory | $116.99 @ Amazon
Storage | Sabrent Rocket Q 1 TB M.2-2280 NVME Solid State Drive | $89.99 @ Amazon
Case | Lian Li Lancool II Mesh ATX Mid Tower Case | $189.99 @ Amazon
Power Supply | EVGA GQ 1000 W 80+ Gold Certified Semi-modular ATX Power Supply | $150.99 @ Amazon
| Prices include shipping, taxes, rebates, and discounts |
| Total | $1076.93
| Generated by PCPartPicker 2022-03-24 14:39 EDT-0400 |
This should be good...
Type|Item|Price
CPU | Intel Core i7-12700K 3.6 GHz 12-Core Processor | $354.98 @ Newegg
CPU Cooler | be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler | $89.90 @ Amazon
Motherboard | Asus PRIME Z690-P WIFI D4 ATX LGA1700 Motherboard | $219.95 @ Amazon
Memory | Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory | $134.99 @ Newegg
Storage | Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive | $114.99 @ Amazon
Case | Corsair 4000D Airflow ATX Mid Tower Case | $94.99 @ Amazon
Power Supply | Corsair HX Platinum 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply | $159.99 @ Newegg
| Total (before mail-in rebates) | $1199.79
| Mail-in rebates | -$30.00
| Total | $1169.79
| Generated by PCPartPicker 2022-03-26 08:47 EDT-0400 |
Reactions: Jason22D
Do you think it's worth going with an aio vs fan cooler for 12th gen cpu's ? I've never used them before
Reactions: Why_Me
Type|Item|Price
| Total | $1169.79
Is 3600 cl18 the sweet spot for ddr4 ? Also, how do you rank nvme in terms of what's important to least important variables ( storage, speed, etc )
Yes, that should be around the sweet spot, but fortunately Intel is less sensitive to RAM speed, so you wont feel the difference unless it is drastic. The reason for that LPX kit is for its low profile with same performance as other brands/variants, along with its height being compatible with full tower coolers like the Dark Rock Pro 4, which is well known for its cooling performance. Other similar kits usually have heat spreaders and then you have to adjust for height and find matching kits, which are rare by the way.
NVMEs with DRAM cache should have generally better performance due to its shorter response time. Other significant factors are NAND type, layers, R/W speeds and NAND brand and controller(less important). You can use this guide for reference, although its not perfect...
Reactions: Jason22D
Latest posts
