Hi all ,I have just left the dark side of Amd and going back to Intel . So far I have I5-3570K , Msi Z77A-G45 mobo , 16Gb Kingston HyperX 1600 ram ,Zalmon Z11 plus case, 2 Cooler Master 120 mm blue led fans that are going in exhaust mode plus the 5 allready in the case , Cooler Master 212+ cpu cooler ,a Cool Power Gamer 1080 Watt Psu ,( I know its not the best ) one 3.5" Fan controller for 4 fans, Pioneer BDC- 207BDK disk player and burner , 4 blue CCT lights , 3 Benq G2255 21.5" monitors , 1 Msi OC Hd 7770 , 1 Asus Hd 7770 , 1 Sandisk Extreme 120Gb ssd , 1 Kingston V200 64Gb ssd , 1 OCZ Agility 3 60 Gb ssd , 1 Seagate Baracuda ( St1000DM003 ) 1Tb Sata3 6Gbs , 1 ThrustMaster RGT Force Feedback Pro racing Wheel , Win 7 Home Premium , games I have ordered are Dirt3 ,F1 2010 , NFS The Run, Wheelman 2009 , NFS Shift 2 Unleashed , I like my driving games , Have all my cables to run EyeFinity in DVI mode ,have a Active Display mini display to Dvi dongal , have Nero Video Extreme for BluRay movie playback .
I am going to OC the Hd 7770`s to around 1050 Mhz , run them in Crossfire @ 2X16 3.0 , Going to OC the 3570K to 4.0 mhz , all the SSD`s will have Firmware updated before install , now I only have 2 Sata 3 ports and 4 Sata 2 ports , and am confused as to the best way to connect all these hard drives ?
1 - use the 120Gb Sandisk for Win 7
2 - connect 1 64 Gb up to the other Sata 3 port for game installs
3 -connect the 2 small SSD`s to Sata 2 in a raid 0 configuration ?
4 - connect the Seagate up to the Sata 2 port
5 - use the first 2 options and conect the Seagate and the OCZ in a SRT mode
If I used the last option would the Seagate perform a little bit better ? I have 21 Gb of Mp music that I will be transferring over to the Seagate as that will be my storage drive .. I`ve done lots of reading and am just trying to figure out my best options before I put this all together , any and all help would be appreciated very much ,thanks Bill
