New i5 2400 build. Need a little advice on a few parts
Brujahnation
Hi all. Long time reader/researcher on Tom's. Getting ready for a new build (1st one in a few years, and 1st intel build in a looong time) , and looking for a few suggestions about a couple of parts. Guess I'll start with what I have sorta decided on so far...
Approximate Purchase Date: over the next few weeks
Budget Range: Prob around 1k 1.2k before monitor
System Usage from Most to Least Important: Games mostly,surfing, nothing too demanding like video editing or anything
Preferred Website(s) for Parts: Normally use Newegg due to prices and having a warehouse in my city (next day delivery!)
Country: US
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution:1920x1080
CPU i5 2400 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
GPU 460 1G http://www.newegg.com/Product/Product.aspx?Item=N82E16814127510
Memory 4x4g http://www.newegg.com/Product/Product.aspx?Item=N82E16820231315
PSU 750W corsair http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Mainly looking for suggestions for a Mobo, thinking of a P67. and just to make sure im not making a mistake on anything here. TY all in advance for any help.
I'd go with an H61 board to save some cash since you can't overclock anyway on the i5-2400. You can still get them with USB 3 and SATA 3 etc. 16GB is also far too much RAM for gaming, even 8GB would be overkill but it's cheap so 8GB is common. 750W is also way too much power for a card like that, 450-500W would be enough for a 460.
I think instead of that build you would be better with something like this personally.
i5-2500k - Awesome value if you plan to overclock.
ASRock Z68 Extreme3 Gen3 - Good overclocking and all the features you're going to need.
8GB Corsair Vengeance LP - 8GB is very cheap and may help in future, there really is no reason to get more than this for gaming.
EVGA GTX 560Ti (Fermi) - This card is great value for money, much better than the GTX 460.
Antec BP550 Plus 550W - Nice solid PSU with modular cables and more than enough power for this build.
Coolermaster Storm Scout - Nice well designed case which is awesome value for money.
Total - ~$750
This would be far better than what you have there for gaming. For storage I would recommend a 128GB Crucial M4 SSD then just wait till hard prices go down and get a 1TB drive or something.
I may go with the i5 2500k, most of the stuff i read suggested the 2400 for gaming since from what i gather you dont get much more for gaming outta the 2500k. And guess i left out the reasoning behind the 750w and the 460. Was planning on getting the single card now, then getting another 460 in a few months, i tend to overbuy on PSU's..lol Guess I could drop down to 8g for now, and get the 2500k. Also was just planning on going with a 500GB hard drive, then maybe make the jump to SSD later on.
The i5-2500k isn't much better than the i5-2400 at stock but you can't overclock on the 2400, you can on the 2500k. With a relatively cheap $40 cooler you should be able to get a +30% performance boost.
I wouldn't bother planning for SLI personally, it's only worth it if you plan to play over 3 monitors or at 2560x1600 etc. A decent single card such as the GTX 560Ti/HD 6950 or GTX 570/HD 6970 is fine for a single monitor at 1920x1080.
