So I have a custome built computer that I bought myself for graduation and it has been really good up until this point.
PC BUILD:
Ryzen 5 1600x 6core
NVIDIA GTX 1060 6gb
16gb 2x8gb G skill Ripjaws V series ddr4 3000
Rose will Quark series 650w platinum full modular psu
Gigabyte GA-AB350-Gaming 3 mobo
And an old hard drive that was in my old computer that I just moved over whose name in the bios is P0:ST31000528AS and this is a 1tb hdd
Although this rig has been giving me great results when I am playing literally anything it took forever to turn on and boot windows so I just bought a samsung m.2 ssd, the 970 evo 500gb ssd. I installed the ssd in the m2 slot after 2 attempts, which was a huge pain because I had to disconnect my case mounted GPU that was not going to come off unless I also disconnected a fan so after I installed it the first time the computer wouldn't display anything and I thought it was my gpu but it was because the ssd wasnt in enough or something because after I took it apart again and put it back together it worked, well the display worked. I was then greeted by a prompt to install boot media or insert bootable drive which was weird so I went into the bios and tried changing the bootable drive to my default but it wasnt there so I had to go back into my case and change the sata port that my hdd was plugged into to another sata port and then I could boot. After I booted on the old hdd it wouldnt stay on long and would restart itself which it didn't do before. At that point I got fed up so I went to best buys geek squad for help and he told me to get a flash drive to install bootable media for windows onto my ssd which I did and then everything went well with the installation but now the problem is that when i am using my pc on the new ssd with windows i still am greeted with random restarts, the occasional blue screen and when I open new windows like chrome my whole monitor goes dark for a few seconds and then comes back also my hdmi sound bar when selected in the settings cuts out or becomes staticy. Please help!
PC BUILD:
Ryzen 5 1600x 6core
NVIDIA GTX 1060 6gb
