New power supply Corsair CX430m or Raidmax HYBRID 2 RX-530SS 530W
Christian Ramirez
7
Hi, Whats up guys
I'm looking for a new power supply, I'm between a Corsair CX430m modular serie, or a Raidmax HYBRID 2 RX-530SS 530W
I look for the amperes and riel volt, the raidmax give me more watts, but I was reading and everybody says raidmax sux and isn't a good option.
Tell me pls what do you think
I like to play games as battlefield and others, but im not oc nothing as well.
My cpu spec:
Gigabyte 79lmt-usb3 rev. 5.0
Asus Ati radeon Hd 7750
8gb ram adata 1333mhz
Cooler master hyper 212
Amd fx 6300 (im not overclocking)
Hard drive 360 Gb seagate
Cd lector
and two fans of 120mm
I would like if you reply guys, thank you so much.
If you like power supplies that explode then get a Raidmax. As the saying goes: reputations are earned, they're not handed out.
Notice that Raidmax does not provide the combined +12V rail capacity so that you would be able to easily compare it with the Corsair CX430M. This is done because the combined +12V rail capacity of the RAIDMAX HYBRID 2 RX-530SS is weak (my educated guess is that it's 28 Amps). The current model of the CX430M has 32 Amps on its +12V rail.
That Raidmax model also has a shorter warranty than the CX430M so that should be taken as a warning.
