New PSU, noisy and Power Supply Surge
VorCrux
Commendable
Feb 7, 2017
I replaced my motherboard and psu with almost the same models, the psu is noisy (before the replacement it wasn't noisy). On the first few days it was fine, I could play most of my games, but then I would go into the same game and the computer would immediately shut down and power up saying that the Asus power-surge was initiated. The difference is that i upgraded my psu from 600w to 700w, whats wrong?
Asus h51m-k
trendsonic lc8700btx
DRagor
Illustrious
Because the new one might need more power. Even if the PC has not changed, so it needs the same amount of power, the new PSU might be less power-effective then old one, and draw more power then old one.
Just plug the PSU directly to the wall plug for a test. If noise and shut downs disappear, you have a problem pinpointed.
Otherwise, like I noted before, most likely defective PSU.
DRagor
Illustrious
Most likely new PSU is defective. Being new does not automatically mean good. Especially if it is making noise from the start. Also, do you have it connected to wall plug directly or through some backup power system?
VorCrux
Commendable
Feb 7, 2017
I have a UPS connected, and the UPS is connected from the wall
VorCrux
Commendable
Feb 7, 2017
But how come the old PSU (600w) could handle the same games I played when it was old and dusty but the new one couldn't?
DRagor
Illustrious
