new system for less than 700$
was955
6
What is the maximum budget?
700$
A) Do take advantage of all the budget or trying to save?
Exploit
B) if necessary - to the extent possible breaking your budget?
100$
2. What types of computer usage (eg, games, graphics editing, office work, HD content, etc.)?
Graphic editing
A) If the computer is designed for specific major programs, write them and how to use (occasional / frequent / heavy / livelihood).
Heavy / income
B) If the computer is designed for gaming, it should be noted:
Eilat games will be played on the computer, for example.
-mhi Natural resolution (max) of the screen connected to the computer (you can also specify the screen size).
Screen Dell UltraSharp U2412M (Digital) 1920 * 1900
-lailo Designed for computer graphics settings (low / medium / high)?
3. Is it necessary peripherals (eg, keyboard, mouse, speakers, etc.)? If so, you can also record preferences models.
Do not have
4. Is there no need to include a component specification?
CPU + memory + motherboard + SSD
5. How important is quiet on a scale of 1 to 8 (8 = have to try and keep the peace)?
6
6. Is designed overclock (OC)? So what (light, medium, heavy)?
Not
7. Do I need to include OS / Office (therefore desirable to specify a preferred version) and / or train a computer store?
Not
8. Is there a preference to purchase the specific camps computer? If not you can also specify a residential area.
Ivory
9. When a planned purchase of computer?
This week
10. Are there any special requests? (Eg support devices / connections such as FW / RAID / USB3 / eSATA, multiple audio connections / optical connection, specific hardware requirements, etc.).
It is better to FULL ATX Case
11. Is it important to keep the horizon upgrade your computer? Is planned a massive upgrade of the computer in the future?
Not
12. Additional comments, various extended details:
Currently I have the following components:
Intel® Core ™ i7-5930K Processor
GIGABYTE X99 Gaming G1 WiFi
Intel® SSD 730 Series (480GB, 2.5in)
Crucial 16GB DDR4
what i build so far is:
LG DVD±RW GH24NS x24 Black SATA OEM 115 1115 22683
Antec 750W 80+ Bronze HCG-750 550 1550 23422
Antec Eleven Hundred Gaming 550 1550 24017
Intel® Thermal Solution BXTS13A installation manual for the LGA2011-v3 socket130 1130 29074
או
Antec Copper Tiger C40
Western Digital Caviar Black WD2003FZEX 2TB Sata III 765 1765 31088
Gigabyte GT740 OC 2GB GDDR5 2xDVI HDMI PCI-E 590 1590
what is your recommendation?
Do you plan to overclock your CPU for enhanced performance?
Although it may not have all your parts PCPartpicker.com is a useful tool for organizing a build, like this:
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($499.99 @ Micro Center)
Motherboard: Gigabyte GA-X99-GAMING G1WIFI EATX LGA2011-3 Motherboard ($324.99 @ Amazon)
Memory: Crucial 16GB (4 x 4GB) DDR4-2133 Memory ($159.99 @ Adorama)
Storage: Intel 730 Series 480GB 2.5" Solid State Drive ($219.99 @ Newegg)
Total: $1204.96
Generated by PCPartPicker 2015-03-15 10:25 EDT-0400
For the parts you have already.
With some added.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.98 @ OutletPC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($124.89 @ OutletPC)
Video Card: Gigabyte GeForce GT 740 2GB Video Card ($95.99 @ SuperBiiz)
Case: Antec Nineteen Hundred Red ATX Full Tower Case ($119.00)
Power Supply: Antec HCG M 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($79.99 @ NCIX US)
Optical Drive: LG GH24NS72 DVD/CD Writer ($17.98 @ OutletPC)
Total: $1671.79
Generated by PCPartPicker 2015-03-15 10:36 EDT-0400
You still have budget. From what site will you be buying so we can compare your local prices?
I know that. Some of these parts are not available in the US, so I assume that you are elsewhere. That also means that prices are different there and some things may be unavailable. I need to know where you are before I continue. There is no sense in suggesting something that is not available to you.
Thanks for that. Will K.S.P do for a site to check availability?
Let's look an individual parts.
I don't know what software you are using and even if I did, it probably would not help much. Only you, your software supplier, or someone in your community can tell you if the GTX740 is the right (or right enough) video card.
The CPU comes without a cooler. It is a 140W chip, so you need something better than the Antec C40 which is rated at 130W; Intel recommends liquid cooling. Here's a site with information on coolers. http://www.frostytech.com/top5heatsinks.cfm Check to see that they will work with your socket. The Copper Tiger does not seem to mention your LGA2011-3 socket.
You could use a lower power PSU, but for business use, Gold certification might save money, depending on the power costs in Israel.
this is what i bought what u think
case: Corsair Obsidian 750D
hard drive : Western Digital Blue 1TB WD10EZEX
power supply : Seasonic M12II-620 Bronze 620W
cpu water cooler : Thermaltake Water 3.0 Performer C
Msi Nvidia GeForce GT740 2GB GDDR5
SATA LG DVDX24 DL שחור OEM GH24NSB0
all is 615$
