Question New z790m aorus eltie dont power on
Jul 20, 2024
Simple, brand new Mobo z790 M Aorus Elite rev 1.2 and brand new 15 14600k.
I built the pc, everything was working, shutdown, now, I try to start the PC and not a single sound, nothing! Just the mobo led blinking really fast... the only thing is during the BIOS UPDATE, I see a red CPU led and the orange qflash-plus blinking, but after is done updating, PC won't turn on 🙁
Anybody can help me? Please 🙁
I tried to:
• update the bios to the last one
update the bios to the first to support my 14th gen i5 cmos clear
• battery removal
• tried a different psu, same problem
• tried without cpu, ram, gpu, every scenario.
• tried to update the bios with just the psu connected
Update your post to include full system hardware specs and OS information.
PSU(s): Make, model, wattage?
Did you use only the cables that came with the PSU being installed?
PSU is a corsair 650watt and i test it with other pc its working perfectly windows not yet installed
This motherboard (verify that I found the correct User Manual).
https://download.gigabyte.com/FileL...1103_e.pdf?v=710a826a8cd1a6a2afacae690763ef3c
First read through the User Manual to verify that all installed components are supported and correctly configured.
Then work through the User Manual step-by-step to look for any errors of omission or commission when the system was being put together.
Take your time, read all fine print, pay close attention to sockets, plugs, and pins.
I have already read this manual i also try With minimum cpu and 1 slot of ram but nothing i think i have a shortcircuit in the mb
