Newb building comp, please help
blakehanson
63
APPROXIMATE PURCHASE DATE: Next week or so.
Budget: <$800
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, movies, internet, home work
PARTS NOT REQUIRED: Keyboard, Mouse, Monitor
PREFERRED WEBSITE(S) FOR PARTS: Newegg, cheapest
PARTS PREFERENCES: Too new to be picky about this stuff
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Please explain what this is (sorry)
MONITOR RESOLUTION: all of the above
ADDITIONAL COMMENTS: This is my first build. I am very new with everything. Ive done research to figure out stuff on my own but can only go so far. THANKA FOR YOUR HELP.
Also, Im just trying to build this comp up for gaming and movies.
Heres what ive picked out so far:
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
HITACHI Deskstar 7K1000.B 0A38005 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145241
PNY VCG981024GXEB GeForce 9800 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133243
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
AMD Phenom II X4 940 Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Black Edition Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
Power Supply=Not really sure what to get. Please any recomendations would be great!
Also, cables and such. Do they come with each individual part or do i need to purchase serperatly? If so, What cables do i need?
Any recomendations or advice on this build.
Thanks again!
I would not buy vista now . Download the release candidate of windows 7 and use that . Its free , for now
Use the money you save to move to a proper AM3 system with a 955 and ddr3 memory .
Then save some more money by buying a ATi 4770 . Depending on the game it benches above or below the 9800gt , but its only $90 and has better software . it also gives you the option of crossfire later
http://www.tomshardware.com/reviews/radeon-hd-4770,2281.html
Have a look at antec earthwatts 500 W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
or
SeaSonic SS-500ET 500W ATX12V V2.2
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151069
Edit :
crossfire and sli is using two or more gfx cards in the same computer to increase gfx quality . The 4770 is ideal for 19 inch lcd's and OK for 22inch 1680 x 1050 panels . On screens with higher resolutions it will struggle
all the hardware will come with cables . Most motherboards ship with a selection
Id also suggest a larger hard drive the WD se16 320 gb drive is a quality product and very reasonably priced
What games do you play? How long do you plan this rig should last? What is your exact screen resolution, or you haven't bought a monitor yet?
Also, about the Windows 7. How would you install it onto a brand new build? Would you have to burn it onto a dvd from another computer and trasfer it over with that dvd? Or what?
The option would really be awesome!
THat's exactly what you do. Just get the computer to post, then plop in the DVD and everyth0ing should work fine. Look up some tutorials on google.
Thats what im gonna do. I love this idea. Its free and will hopefully be better.
Also, does anyone have windows 7 who would like to share their experience on the new OS??
Thanks!
Ok, so i just saw this cpu for only 20 dollas more. Do you guys think I should use this cpu instead of the one i have posted up above?
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
And will this new cpu work with the motherboard up above?
Also, What are the advantages of having a faster cpu for game play. Rather than having a better video card?(which i believe the 4770 is a good one, right?)
Thanks!
windows 7 works really good, though, i had issues with my radeon x1600 mobility, had to hack the inf file for old catalyst to see my video card
but since you have new components, you won't have any problem like that
