Specs:
https://pcpartpicker.com/list/ZtZVwh
Problem:
The main problem is the Monitor not detecting any signals from my newly built PC with GPU. I've been using the HDMI cable to hook up the GPU to the monitor. Furthermore, the MoBo displays a red LED "00" at the bottom-right side as seen in the attached picture (if that matters). Even with the GPU attached, it shows the same red LED "00."
What I tried:
I double-checked all of the wiring to the MoBo including the Fan Connectors and Case Connectors, and they are snugged into place. I took out my CPU Cooler so I could see if I damaged any pins on my CPU (it doesn't look bent). Then, I tried removing the GPU from the PC and tried to connect the MoBo (with USB-C Connection) to the HDMI port on my monitor (didn't work because my CPU doesn't have an integrated graphics unit).
Picture (My PC build turned ON without GPU attached):
View: https://imgur.com/a/DcffVhK
Extra Info:
Whenever I power on the PC, via the PC Case, everything seems to run fine. The fans of every component runs, including the MoBo and GPU, and the LED light works on everything including the 4 identical RAM sticks I have placed. Also, when I power down (even when holding) the PC Case's Power Button, the PC doesn't turn off; I have to manually turn off the PSU. Then, my keyboard and mouse don't seem to lighten up when connected (RGB lights); I'm thinking it's unable to be recognized as peripheral devices by the MoBo.
Thoughts:
I'm willing to bet that there's an issue with either the CPU or the Motherboard, and I am so stressed out right now because none of these parts were cheap. I am desperately in need of help, and I thank anyone who can offer any form of advice.
Problem:
What I tried:
Extra Info:
Thoughts:
