Newly built PC won't turn on, help?
Zerodea
5
Hi guys,
I recently built a new PC specifically for gaming and video editing, as you probably guessed, I was really excited to get it up and running, and I put everything together very carefully (this isn't my first build, but it's my first one with the specific parts that I used) over the course of about 6 hours with my dad.
Here's the parts list:
CPU: i7-4790K
Mobo: MSI Z97 G45 gaming
CPU cooler: Noctua NH-D14
RAM: Corsair Vengeance Pro 16gb 2133 mhz
HDD: Seagate Barracuda 2tb
SSD: Samsung 840 EVO 250gb
PSU: Corsair RM 850 watt Gold-certified power supply
Case: Corsair 750D Full Tower case
I'm not sure if that helps at all, but I would like to know if there's anything I could do to remedy this situation. Or if the parts are even compatible with each other, such as the i7-4790K and the Z97 chipset. (PCpartpicker said they were, but I'm not 100% sure)
Are there any common mistakes that I might have fallen prey to that could cause it to not turn on?
Are there any common remedies to this problem?
Any help is greatly appreciated! Thanks!
Go through that checklist it could be a really simple problem.
