https://pcpartpicker.com/user/A_Quincy_Joker/saved/z3DYJx
Hi I need help finding a case with better CPU Cooler clearance for the Chromax NH-D15 and USB ports towards the front of the case (my cats like to reset and shutdown my PC) with Airflow as a top priority. I don’t care too much for RGB in the case as my components already have some. My main issue is the amount of clearance required to clear the Tempered Glass Panel (190.2 MM or 7.5 inches approximately) and the tall RAM spreaders. The measurement from the bare metal of the inside of the case to where the fan would end up is 200.4 MM altogether with with motherboard and CPU cooler.
PC Specs:
Corsair Crystal 460X Case
Corsair H1200i Platinum PSU
ASUS ROG X470-F Gaming Motherboard
Ryzen 7 2700X 3.7 GHz 8-Core @ 4.3 GHz OC
G. Skill Trident Z RGB 8 GB x2 3200 MHz 16-18-18-38
Chromax NH-D15 CPU Cooler (162 MM under normal circumstances aka low profile RAM)
RTX 2070 SUPER 8 GB Founder’s Edition
PC Specs:
