NIC & Cable Modem help!!!!
JPWRana
114
Which is the best Cable modem / NIC combo? I currently have a d-link standard cheap 10/100 NIC with a Terayon Pro Cable Modem... i think there has to be a better combo out there... right?
And also, what if i were to use one of those new 1000Mbps NIC's... are they better than the 10/100 NIC's? In which ways are they better or worse than the 10/100 NIC's? Are there any 1000Mbps (routers + hub's) boxes out there? If so, would it be worth it with a new cable modem? Or is my terayon pro good enough?
If it may help, my cable service provider is Adelphia, and I live in the Los Angeles, CA area... specifically, near El Monte.
I COULD REALLY USE SOME HELP HERE!!!
Terayon modems are considered one of the best available as for the nic the one you have is fine there are a few others notably a 3com model that do some of the processing onboard but this just helps your cpu a little .. since cable dosent exceed 10mbps there isn't much room for improvement other than changing from adelphia to a better provider like optimum online ( they run at 8 MB down and 1 MB up on avg.)
lagger
<b><font color=blue>Checking under my North<font color=red> AND</font color=red> South bridges for <font color=green>Trolls</font color=green></font color=blue>
No fair! I want 1M upload! My ADSL only does 1.5M dl, and 128k upload 🙁 🙁 🙁 🙁
Can get enhanced for $129 more/mo, taking me to 6M dl, but still not much of an ul, @356k.
No cable modems round yonder...too far from "civilization"
While wearing syran-wrap speedos, my shrink had the nerve to tell me "I can cleary see yer nuts!"
yeah I'm jealous of the opimum online guys too I have time warner road runner and get "only" 2 mb down and 385 up
lagger
<font color=blue><b> Roll another bummer and leave it on the sideboard Catherwood </font color=blue></b>
On-board processing only works in WinXP/2000 and is not turned on by default. You have to use a registry hack to get it to work:
<A HREF="http://www.winguides.com/registry/display.php/954" target="_new">http://www.winguides.com/registry/display.php/954</A>
