Howdy great peeps,
So after getting my H110 & installing it,
decided to do some OCing, the result is pretty nice!
Used in my setup:
CPU: I7 4790k @4.5Ghz - 1.204V
Cooling Paste: Arctic MX-4 (pea method)
CPU Cooler: H110 (stock fans, since they are quite decent, 100%)
Motherboard: ASRock Z97 Extreme4
PSU: EVGA SuperNova 850W 80+ Gold
GPU: x2 MSI GTX 970 Gaming 4G
SSD: Samsung 850 PRO 256GB
HDD: Samsung HD100IS 1TB
RAM: Corsair Vengeance 1600Mhz 8GB
Case: Graphite 760T
Testing method:
Prime95, Small FFTs
Disabled all power saving options in BIOS, throttling options and so on.
(Only kept temperature protection activated)
First tested 4.5Ghz on 1.199V, but after 2 hours testing it failed 🙁
So upped the voltage to 1.204V, which seems so far to be the sweet spot,
the temperatures did not exceed 68c so that is very satisfying!
(Only tested 30 minutes, will test for 6 hours more - the temperatures are amazing though)
Direct link: http://i.imgur.com/MnIQGLL.png
Could potentially go higher, but a 0.5Ghz OC is good enough for me.
Post any thoughts & comments you may have!
Much greetings,
Mike
Used in my setup:
Case: Graphite 760T
Testing method:
Prime95, Small FFTs
Much greetings,
Mike
