No Audio during TV Capture
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.video (More info?)
When selecting "ATI RAGE Theater audio" error msg "device is not responding
close any other application using device and try capturing again.
When other option "SoundMAX Digital Audio" is selected. . . no audio seems
to be available. It will however let me capture the video.
Have you checked that Line In isn't set to mute in the System Tray?
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
"Bob-O" <BobO@discussions.microsoft.com> wrote in message
news:9A1D6440-F747-4754-B1D7-35B22389438A@microsoft.com...
> responding
Thanks for reponding!
My set up is as follows
Program: Windows Movie Maker
Computer: Dell Dimension 4600
TV Tuner card: ATI 64MB All-in-Wonder 9000
Sound Card: SoundMax Digital Audio
TV signal via coax cable connector on ATI card.
Two input device options are available "ATI RAGE Theater audio" and
"SoundMAX digital Audio".
When SoundMax is selected. The program will capture video but no audio.
I have verified that all of the mixer recorder inputs are "not" muted and
the volumes are up. I have selected each of them. No audio is present.
When "ATI RAGE Theater audio" is selected, the input meter pings with audio
signal present. The "Input Source" is grayed out and says "none".
When I try to proceed with the capture, a "device not responding Close any
other application using device and continue" error is given. No other
programs open?
Note tv capture works fine with xp media center My TV, but I cannot import
the file type created for editing.
Per forum recommendations in the WMM forum
I have: reloaded ATI hardware drivers, reverted to MM1, disabled sp2 firewall
> www.coribright.com
> > responding
When you select Sound max, you need a seperate audio cable connected to the
line in of the sound card.
Check out http://www.thegreenbutton.com/downloads.aspx for a utility to
convert the DVR-ms files to something more editable!!
Graham Hughes
MVP Digital Media
www.dvds2treasure.com
www.simplydv.com
news:3CD469E3-11B0-4FE6-A035-5F80BF050257@microsoft.com...
audio
> programs open?
firewall
> > www.coribright.com
> > > responding
seems
