When I insert my GTX 1050ti GPU in my pc, all fans work, the CPU fan, the GPU fan, 1 external fan. everything works just fine but pc does not boot. there's no single beep that comes when booting. When I remove the GPU and insert one spare GPU I found (GT 630) Everything runs just fine. PC boots up, there's display. All Good.
When I try to start up with my GTX 1050 Ti, It doesn't even boot up.
If I'm Correct the GTX 1050ti and GT 630 Power Consumption is somewhat similar. I have a 450W PSU (iBall)
What can be the fault? Is my GPU Faulty. It first time I'm plugging it in.
My PC Specs -
AMD FX 6300
8GB DDR3 1333 MHz Ram
1 TB HDD Seagate
450 W iBall PSU
VGA Monitor Dell
gigabyte ga-78lmt-s2pt Mobo
Please Help. 😀 😀
Thank You.
My PC Specs -
AMD FX 6300
1 TB HDD Seagate
450 W iBall PSU
VGA Monitor Dell
Please Help. 😀 😀
Thank You.
