No bios screen or sound from my HD Audio output
Jamie_103
Hello,
My first time posting, I am having trouble with my HD audio output on Win 10. First off the soundbar previously worked fine now it does not. If it is plugged in I either get black screen upon boot or it bypasses the ASUS Bios F2/esc section. Im am using hdmi out on my pc and Toslink/spdif on my soundbar using a convertor in between It previously worked and would come up ER-HDMI-RX now it is Just at the default realtek audio. I have scoured the web for a solution even did a fresh Install but same problem. Any Help would be much appreciated. I downloaded nvidia graphics card driver and it came on and worked but when I rebooted it dissapeared. I reinstall Nvidia driver but not working this time. I have win 10 with Nvidia GTX 1080TI WIN 10 1809 version. I have download realtek HD audio manager but there is no sound.
I just fixed the Issue was missing intel uhd control panel. this gives you the correct drivers to HD audio, cant put my finger on exactly why it worked it just did. music burst out of my sound bar hdmi as soon as it downloaded.
