No Booting Sound
Evewin Lakra
24
No Booting Sound is coming No POST.
Just now I got into this problem.
My Pc is not booting........(No Booting Sound is coming) I tried everything I know.
but its not letting me to even enter BIOS.
all the fans and optical drives gets power.
No display on the monitor.
when I start my computer and press the power button to boot my computer I can only see the keyborad LED Flashes just ONCE and after that Nothing happens and every fan and MOBO LED LIGHTS GLOW.
But No Beep (POST) 🙁
What should I Do.
My config is:
AMD ATHLON X4 630
Biostar TA785G3 HD (MoBo)
Corsair 400 watt power supply.
You're right.......its not my Biostar motherboard fault.
Earlier I along with most of the geeks of the tech world whom I know also suggested the motherboard is the common thing which goes bad and CPU goes bad in very rare occasion and that rare occasion happened to be in my case.
I travelled 150 km from my city Jamshedpur to Ranchi because
Abacus peripherals pvt. Ltd.(which is the official RMA service center of BIOSTAR India)
Their Office Address:
499 /a/2 2nd floor , pee pee compound , sighee marg ,
Ranchi -01
Phone 0651-2330584
Abacus peripherals branch is not located in my city jamshedpur and that is why I had to go to Ranchi.
I was so confident that If Abacus peripherals will not be able to repair my motherboard then I'll buy a new Gigabyte GA-78LMT-USB3 motherboard and will return home happily but it turned out to be opposite.
Abacus peripherals engineer checked my motherboard in front of me he checked all the mosfets and chokes of my biostar motherboard he even changed the BIOS CHIP with his own to see if it works or not.but he was not able to find the problem and lastly he told me that it may be a Problem of the Southbridge CHIPSET which he cannot repair over their. so I happily decided that I'll buy Gigabyte GA-78LMT-USB3 so that I can turn my computer ON and the moment I went the other computer shop which sells AMD mobo and Processors he checked the new motherboard with my AMD Athlon II X4 630 and the same thing happened in that new motherboard also. NO Boot No POST. finally we all came to the conclusion that my AMD Athlon II X4 630 Busted Without Overclocking by running it in STOCK-Speed. it served me 3.5 years and then it got busted.
My 1st P.C. which is intel based HCL Beanstalk 9 years old still running.
and my laptop which is also intel based 6 years old still running fine.
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash4/1622559_10202922288595638_814961991_o.jpg
Enjoyed the trip with great food but it would have been great if I was able to solve my AMD P.C. problem which didn't happen but never-mind I like to thank everyone who supported me and helped me in my trouble time.
Hope soon I'll be able to build a budget to build my new RIG so that I can get back to my work which I'm not able to do right now by using my low power dell laptop :)
