[SOLVED] No Display Help Pls!
vabbymgl
So I've had my pc for a few months, and lately I've switched GPU's a lot I've been trading gpu you could say and i got a brand new Red devil RX580 8gb yesterday and my pc was working just fine yesterday till today afternoon my monitor (HKC g4 plus 144hz) starts showing red,green,blue flickering colors
At the time i was running my monitor and tv as display and when my monitor was doing that my tv was alright and i turned it off and when i try to turn on my pc it stops showing display
My pc turns on all the rgb fans work and the motherboard LEDs light up and everything lights up and spins
Thing I've tried:
Reinstalling the RAMs
Clearing CMOS
Running hdmi display from motherboard
Pc:
Ryzen 5 1400
Asus prime a320m-k
2x8gb teamgroup vulcan 3200mhz ram
Rx 580 8gb
1250w Greatwall 80+ bronze psu
With that, 1250w Greatwall 80+ bronze psu , it looks like you're running a mining operation. You might want to see if the GPU doesn't throw any issues n a donor system with at least 650W of power to it.
In the interim period, see if you can source another PSU to power up the system.
See if reseating the GPU helps.
FYI,
The processor you're working with doesn't have onboard graphics.
FYI,
FYI,
I've used the bios switch on my gpu and used only my monitor it was working i was so happy but when i connected my tv it again did the problem
And it doesn't work anymore
I don't think the psu is the problem cuz I've had it for months
