Question No display on monitor with GPU in PCIe x16 slot, but no problem in x8 slot ?
dforrest
99
I have part of the problem covered by the ""No POST", "system won't boot", and "no video output" troubleshooting checklist" thread.
I have a GTX 1070 graphics card on a Gigabyte Z370XP SLI motherboard. The graphics card has been working for months in the PCIe 16x slot. Suddenly, when I start the computer, the EVGA backlit logo is no longer lit and the card fan no longer runs. The monitor receives no signal. I am sure that the POST has completed, with the normal single beep, and from the case fans and other sounds, I am sure that Window has started, but with no monitor display.
If I remove the same graphics card from the x16 slot and install it in the x8 slot, all works perfectly.
Can anyone help?
BIOS replacement appears not to resolve the problem.
In the past, when I had problems with USB ports, I would remove these in Device Manager and they were corrected and replaced when I re-booted. Can I do this with the problem PSIe slot by removing its Device Manager entry?
