Question No display on monitor.
ExtreamChaozZ
229
Hiya there,
I am currently testing my new motherboard, ram, and cpu which i plan to use to upgrade my system. Unfortunately im getting no display, the board lights up and the cpu fan spins but no signal. If anyone has any ideas on how to fix this that would be amazing.
Heres a list of the things i have tried.
  • Reseating cpu
  • Checking cpu pins
  • Reseating ram
  • using only one dim in each slot
  • using only one dim in each slot with the other stick
  • reset cmos
  • checked my cables
  • checked my psu
  • checked cpu ov cap
  • tried other hdmi ports and cables
  • tried with os and without os
I have a motherboard speaker but im not getting anything out of it not even a beep to let me know if its powered on. I have check the manual to ensure everything is correct which it seems to be.
Specs:
  • Asus rog strix z370 f gaming motherboard
  • i7 8700k cpu
  • corsair 16gb (2x8) rgb vengence pro 3000mhz
  • stock intel cooler for testing purpose
I dont get any warning lights in asus on board leds such as red for cpu or yellow for dram. I only have the orange led for power lit.
Check pictures here:
View: http://imgur.com/a/78BGm1i
Update:
- I have tried removing the ram completely to see if the error leds light up to notifiy me if theres a problem with ram. No lights just the same as before.
- I also tried removing the cpu and turning the motherboard on to trigger the cpu error light, but nothing happend the motherboard didnt boot.
