Question No display w/ boot LED
jOSEPH_de
28
Just built a new PC and it's not booting. Everything seems to be on and running but the display is just black with a white BOOT LED on the motherboard. I've tried everything like clearing CMOS, reseating RAM, checking all connections, and trying different display ports. I also already updated the BIOS using M-Flash. Any advice on what could be the issue?
Parts: https://pcpartpicker.com/list/CdrwH2
EDIT: Does anyone know a store I can go to in order to pay someone to fix this?
This unfortunately didn't work either so the storage must not be the issue. The boot LED is still on when I try this. Any other suggestions?
Have you tried booting with your video card mounted in the 2nd PCIe x16 slot? If that does not help i can only suggest removing the motherboard and try booting outside the case. There could be a short somewhere inside the PC causing a problem.
Yes, I did try this. I guess I'll take it to Best Buy and hope they can fix it
