No help from BenQ website.
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello,
I have a specific problem that cannot be answered wby using FAQs. I use
the http.support.benq.com website, fill out a form and I get a letter
directing me to the same site! I have the 866 number but I know what
I'll be facing because on my other Benq I was given an incorrect
firmware number. Lucky that I caught it before flashing the drive.
I'm hoping to find someone here to help me:
I bought a BenQ DW 1620 PRO, and I searched for the latest FirmWware
for that model. I somehow selected G7M9. Can't remember why or how.
When it came to download the FirmWare, I got an error emssage that read
to the effect...the firmware you are about to flash is OLDER than the
one in your unit. FLASH or EXIT. I clicked FLASH by mistake!!
So the firmware I use now is 2x16x and 4x/16x instead of 4x/16x and 4x
16x. Fine! It runs but with a few little message that don't seem to
bother the viewing, but it WILL NOT BURN a DVD.
What I would like is the number of the firmware that follows the G7M9,
or any one after that number for my unit I tried two of the latest
numbers and a message said that the firmware was NOT for my unit.
Doorstop? Boat Anchor? Garbage can?What's my next move.
ThanX! Mike
Hi,
Pls try the Firmware B7U9 dated 22 Feb 2005 from benq.com Singapore
http://support.benq.com/front/BenqMain.asp?MenuHead=128&ShowType=program&FileURL=service/driverlist.asp&Dataid=16041&downloadclass=Driver&product=3731&langu=null&ops=2756&GenMenu=&RootId=undefined
Hope it helps.
Peter
"axipolti@yahoo.com" wrote:
> Hello,
> ThanX! Mike
Hi,
Try download the latest firmware B7U9 dated 22 Feb 2005 from banq.com.sg
Link:
BTW, the firmware you preiouslly installed is for DVD rom only, not for DVD
R/W drive.
Hope it helps.
Peter
> Hello,
> ThanX! Mike
Sorry, wrong post "> BTW, the firmware you preiouslly installed is for DVD
> R/W drive." , I meant was that the firmware G7M9 should be B7M9?
If yes, go ahead to download the B7U9 from benq.com.sg
Peter
"Peter" wrote:
> Hi,
> Link:
> R/W drive.
> Hope it helps.
> Peter
> > Hello,
> > ThanX! Mike
