Hi
I was using Gigabyte RX 5700 xt oc for more than 6 months. Cpu is Ryzen 5 3500 and Psu is Corsair gs600. Mobo is B450 Tomahawk Max.
It was working fine until today. Now there is no signal from its DP or HDMI out. Usually when I start the PC the fans run loud at full speed for a couple of seconds before settling down. Now the fans are continuously running at full speed. I tried the GPU in another PCI slot, it didn't help. Tried tricks like using single ram stick, removing all hard drives, USB devices, resetting Bios battery, still nothing.
The Mobo has debug LEDs of which VGA is lit, indicating some problem with graphics.
Monitor is MSI MAG241C. Tested it with another source it's working fine.
One more thing, couple of tiny white LEDs on the GPU used to flash while playing games. I read that it could be power supply issue but I never had any problems in gaming for 6 months. The Psu is over 7 yrs old, could it have caused this sudden failure? Or the GPU was defective?
I believe the CPU has no integrated graphics so I am unable to test for other problems. No spare GPU either.
Gigabyte service centres are closed tor two weeks due to lockdown.
Is there anything I can do further to get this fixed? Appreciate any help.
