CPU: AMD Ryzen 5700X
Cooler: Thermalright Peerless Assasin 120 SE
Mobo: MSI MAG X570S Tomahawk Max Wifi (BIOS ready for 5000 series)
GPU: Gigabyte Gaming OC Rev 2.0 GeForce RTX 3070
Ram: Teamgroup T-Force Vulcan Z 8GB x 4 (have tried with just 1 stick in)
PSU: Corsair HX750 80+Platinum
First boot before case install, it cycled through the EZ debug lights 1-2 times before POST, but I think this is normal for this mobo. Test went fine, temps were low and stable, all memory/ssd detected...finished install.
Working fine for a few hours. Updated windows, debloated windows, installed Steam and Firefox and as I was importing my bookmarks I lost display and noticed the mobo ez debug CPU light was a constant red and only shutting down the PSU would turn off the PC.
When I power on, all the RGB on GPU, case, and mobo come on and fans spin. Debug light will go CPU red, then it will cycle the debug lights (like during first boot and cmos reset), but eventually land on solid red CPU. At this point i can only shut down PSU to turn off ***except for the time i tried to boot with no GPU, that time it went red CPU light to white VGA light and it let me power down with power button.
Tried to go through the "No POST" checklist, but can't do some of the last ones.
The issue persists and unfortunately I do not have compatible spare parts to test with.
Any help or suggestions would be greatly appreciated. Thanks
- trying with only 1 stick of RAM
- trying with no GPU (CPUlight>VGA light>only time it allowed me to power down with power button)
- resetting CMOS
- Reseating all cables in mobo and PSU
- removing and inspecting cooler, thermal paste coverage was fine
- removing CPU, pins were fine and no debris in mobo receptacle
- reinstall of CPU/cooler/gpu/cables
