Hello. I am having a fun time getting my new system to work. On pressing power button, processor and case fan start up and work, but screen stays blank. I get no beeping. I know the speaker works because i get the correct error response (the beep codes) if I boot up with no memory installed. Both the 24 and 8 pin power connectors are hooked up correctly.
I'm at wits end. I've tried taking the motherboard out of the case and put it on a wooden table to make sure it wasnt a grounding short. All components are brand new, and much better than the old junk I've been using so I don't have anything I can swap out to try to limit down what is wrong.
Here's what I have in the system (when stripped down):
Intel Core 2 Duo E4300
P5B Deluxe
Antec Smart Power 2.0 SP-500 500W Power Supply
COSAIR XMS2 DDR2 800
GeForce 7600GT (no external power needed)
Is this likely the memory or the motherboard? Is there any cheapish memory I could go pick up at a Best Buy/Circuit City/Comp USA place that I could use to test? If I don't figure this out soon it's gonna stay in my head and possess me - and that's not cool.
Thanks for any help you can give.
Bryan
P5B Deluxe
Bryan
