Hi again .
To Moxy95
You have a nice treat here dude
As allays happens at the end "it`s some odd problem " i think you will end up with
On you place i will go 1 by 1 ...........
1. Check you proper placemont of the old Motherboard in the New Case - CiT Mars
- you may have skrewed on wrong place the bolts under the motherboard -> check this
- you may have missplaced the motherboard and you have cross-cirquit on the motherboard - that`s why it may power off instantly when you power on
- take all components out of the case and install "outside the Box" - Motherboard + CPU + CPU FAN + 1xRAM + GPU + PSU
2. Make sure you connect all power cables :
- 1x ATX 20-pin power
- 1x ATX 4-pin power
- 1x ATX CPU power
All white power connectors !
http://h10025.www1.hp.com/ewfrf/wc/document?cc=bg&lc=en&docname=c03343058#N780
3. Make sure you have connected the GPU 1X75 Watt 6-pin PCI Express power connector
http://www.guru3d.com/articles_pages/msi_radeon_7790_oc_review,6.html
4. Make sure you have proper connection of Front Panel pins-cables of the CiT Mars Case :
- i can`t find Manual for this case look in you box for this one ........... use it if you find it
- i see there are LED fans and some diplay on the Case !!!!!!!!!!!
http://www.aone.co.uk/LI.asp?ProductID=3021&ProductImageID=0
- is there an LCD panel on you case Front ?
- is there any extra power connectors for this LCD pannel ?
- is there any extra CPU fan connectors for this LCD pannel ? ( i see fan readings on the picture for this LCD )
- post picture as the others have asked you above !
My theory is that you have some mess up connection and something is telling you mobo to restart or something .......
F.E. if you have conected this LCD cables on the CPU fan conector on the motherboard and you have not connected the CPU fan at all this may power of you mobo in loop .......
Use this schema to connect the Front Panel cables :
http://h30434.www3.hp.com/t5/Desktop-Hardware/Motherboard-manual-for-P7-1414-desktop-MSI-MS-7778-Jasmine/td-p/2597959
If you have found the Power button then :
- disconect all Case Front Panel cables and use screwdriver to short the Motherboard power on pins !
- if i`m correct this are pins 8 and 6 from the link above
5. About the PSU
I`m totaly agree with ko888 - this HD 7790 is under 100W on LOAD
SO you can safely can test with other PSU - 360 - 400 W
You have 600 W - that`s great - incompatibility with HP Motherboard ? ............. i`m not sure ...... the mobo is able of running 100W CPU and you have 65 W ........ my guess is that you have other problem here than PSU ......
SO testing with other PSU will not harm - you will not run 3D games under testing PSU after all
If you do all 5 steps one by one i`m sure you find the problem !
